  3. pick and place file - metric mils conversion
  • Subscribers 161
  • Views 2527
archive over 18 years ago
Hi All,
Assume your board is designed with mils setup and you use mils. Is there a method to generate 'metric'  pick and placement report WITHOUT changing the original setup file ( already use mils ). Because the conversion is a mess for the brd file. I takes too long time ( and may convert 24.99 instead of 25- if the accuracy setup is not optimized) and this may result many DRC's in the brd file.
And I wish the the allegro will give metric and mils for the same time in the future. Especially for measuring some distance .
Thanks for the answers.
Ahmet OZSOY
Originally posted in cdnusers.org by AhmetOzsoy
    For 1MM, what allegro should answer?
    39.37007874....... and so on.
    Changing unit ans you ALWAYS have roundoff problems
    MM to Mils: divide by .0254 : heavy roundoff problems
    Mils to MM: multipli by 0.0254: only accuracproblems:
    I have chose to work ONLY with MM's
    Originally posted in cdnusers.org by jch teyssier
    I can give you a round-about way, if you don't like to re-specify the database to get the MM pick-n-place.
    Out put the X-Y file to excel
    Create a formula to make the conversion in excel
    Output the file in .txt format
    You can then cludge it back into a placement.txt file and import that to a MM database.
    If I REALLY felt I needed to do that I would. I would prefer to change the database (setting MM decimals to 2 places) and export from Allegro. I don't see rounding as a real issue now-a-daz. Fab vendors couldn't really care about your accuracy. They care LOTS MORE about fabrication issues (line widths, spacings, impedance, etc.) They can pretty much drill anywhere; they worry about their own fabrication accuracies; and being manufacturable.
    Just being me. :)
    Mitch
    Originally posted in cdnusers.org by cadpro2k
