  3. .brd to .pcv conversion - problem with .pcv
  • Views 1037
archive over 17 years ago
I'm admin to an online tool which converts .brd files to other formats. Recently I have received a complaint from an user that he cannot be able to read/open the .pcv file generated.
He has requested for PCV extraction and the tool has generated .pcv file. When use tries to open this .pcv file from PCB View Station(SUNUP software), he receive a dialog box with an error:
"Scanf Error Board Data Info:
Line: .......                            "
The .pcv file has been generated using allegro 15.7 and 16.01, and the error appears for both these files.
Any suggestions/solution for this issue?
With Regards,
Prakash
Originally posted in cdnusers.org by knagap
    archive over 16 years ago
     Did you ever solve this problem? What format is .pcv? What is the URL of your online .brd translationwebsite?
