  3. via on bga pad, no drc showing
  • Subscribers 163
  • Views 13532
archive over 17 years ago
I have a board that was layed out by a contract designer and apparently he routed a via at the center of several BGA pads but it never shows up as a drc error. I can aslo recreate this on other boards. I have same net drc turned on and pad to pad direct connect set to not allowed....but it never shows up as a drc error. Is this a known issue? Using SPB15.5.1
Originally posted in cdnusers.org by padmaster
    You need to look at bb via separation. What is the issue anyway? Are you using filled vias or not? Via in pad on BGA *can* work if finished out correctly.
    Originally posted in cdnusers.org by redwire
    This is a thru via, not a BB via. We also specify all vias under BGA's be soldermask plugged. So we have a plugged via occupying the same space as a ball pad = no connection.
    First image: The via is touching the pad origin, I get no drc error.
    Second image: The via is not touching the pad origin, it gives me a pad to via drc error.
