  3. Regarding Reference Designator / reuse / renumber /...
  • Subscribers 163
  • Views 20599
archive over 17 years ago
My quesiton is the following, and is looking for any comments and experience.
I am converting from Orcad( Design Entry CIS) to Concept( Design Entry HDL) for schematics entry. From Orcad, I am able to renumber the whole schematic, or set all reference designator to ?, so that I can update the entir design.
Now, in DE HDL, I see that reference designator started to be ?, and after I "export physical", I can then see the updated refdes like R1, R2..etc.
How do I setup so that I can see all the reference designator converted to ? such as R?, U?, D?..etc.
Also, I am looking for refdes reuse setup. For example, I have deleted R5 and R7, how to I make the later added refdes does not use R5 and R7, but continue from the largest value. Or, vise versa.
Any ideas?
Your helps are much appreciated.
Originally posted in cdnusers.org by jasonhuang@mic.com.tw
    Hi Jason
    There's 2 levels of property in DEHDL - soft and hard. Soft properties are typically system assigned (like by the packager when Export Physical is run), and these soft properties do not need to be set (can have a value of ?). Hard properties are set by the user and need to have a value (other than ?) otherwise an error is generated on Save in DEHDL.
    The LOCATION property is a hard property, the equivalent soft property is $LOCATION - so in the sch everything that has a LOCATION property needs to have a value set to save without an error.
    It sounds like your schematic used hard LOCATIONS - which leaves you with 2 options:-
    1. Manually set all the LOCATION properties
    2. Change the LOCATION property to $LOCATION (using Global Update)
    The second is the easiest - once this is done the sch should save and export physical OK (as long as there are no other errors), and the $LOCATION property will be populated by backannotation.
    Cheers
    Andy
    Originally posted in cdnusers.org by andrewjw
    Hi Jason
    Cheers
    Andy
