  3. Remove Netlist ?
  • Subscribers 161
  • Views 16139
Remove Netlist ?
archive over 18 years ago
Is there an easy way to completely remove a netlist from a board database? Any help would be greatly appreciated.
Originally posted in cdnusers.org by LRCohen1961
    If you want to remove all logic in a design you can read in an empty 3rd party netlist using File > Import >Logic; Other tab - browse for the netlist. Use the checkbox "Supersede all logical data. The netlist (netlist.txt) would consist of the following lines:
    $PACKAGES
    $NETS
    $END
    Originally posted in cdnusers.org by Trykon
