  3. How Resistor Array SIGNAL_MODEL
  • Subscribers 162
  • Views 14793
archive over 18 years ago
Dear Friends,
How can I assign the SIGNAL_MODEL for a resistor_array/network with four resistors ( 8 terminals) inside the package. If one resistor is used DE HDL or Allegro can generate the models automatically. How can I define it from the schematic library( part developer)?
Thank you for your answers, Regards
Ahmet OZSOY
Originally posted in cdnusers.org by AhmetOzsoy
  • JeffJ
    JeffJ over 18 years ago
     Use Setup Advisor.  On Signal Model Assignment dialog select "Create Model" and follow dialog to define an ESPICE device.
    Here is an example ESPICE model for 8 terminal, 4 resistor device:
    (8P4R_0402_22
    (ESpice ".subckt 8P4R_0402_22 1 8 2 7 3 6 4 5
    R1 1 8  22
    R2 2 7  22
    R3 3 6  22
    R4 4 5  22
    .ends 8P4R_0402_22" )
       (PinConnections
        (1 8 )
        (8 1 )
        (2 7 )
        (7 2 )
        (3 6 )
        (6 3 )
        (4 5 )
        (5 4 ) ) )
