  3. Routing not possible from pad in supply net
  • Subscribers 163
  • Views 13301
archive over 17 years ago
hi, While routing the supply net from IC pad,the track does not get connected either from pad or from track.It remains in hanging position. while if net is highlighted the related unrouted pad & routed paths get highlighted.It happens only for few pads like of IC & Cap. All other get connected. can anybody tell the reason behind this behaviour of routing & solution for it.
Originally posted in cdnusers.org by swatik
    Check for a route keep out area associated with the unconnected pads.
    Originally posted in cdnusers.org by Hpattie
    Do you have DRC set to NOT allow the trace to connect? Sometimes if you have DRC set to "not allow" routing, you can't route. Click on "allow DRC" when trying to route, and see if that makes a difference.
    Good day.
    Mitch
    Originally posted in cdnusers.org by cadpro2k
