  3. ORCAD Multiple Search Properties
  • Subscribers 163
  • Views 13350
archive over 17 years ago
Hi, Just got ORCAD v16 CIS up and running with our database and I like the search by properties feature. However there are two search lines available, the first line is works say, Value = 0.1UF however if I look for the the 50V parts within those results using the second line, Voltage >= 50V I get all the voltages I had before above, eqaul and below to 50V. It's as if the second line doesn't work at all? Any thoughts would be greatly appreciated?
Originally posted in cdnusers.org by markrose01
    I would suggest loading the latest hotfix if you haven't already done so.
    BillZ
    EMA Design Automation
    Originally posted in cdnusers.org by BillZ_EMA
