  3. Automating Gerber Generation
  • Replies 8
  • Subscribers 160
  • Views 19771
wERerABbiT
wERerABbiT over 17 years ago
Hi All,
I would like to write a skill program to automate the gerber generation. May I know:-
1) Are there any functions (skill or axl) that allows you to manually generate a certain gerber layer rather than using the MANUFACTURING -> ARTWORK dialog window?
2) Are there any functions that allows you to import a predefined setup for the Artwork Layers? If not, any suggestion on how to do this in a skill program?
Thanks All
  • eDave
    eDave over 17 years ago
    Here is a function that I would use (if I didn't output ODB++ exclusively these days):
    defun( MY_GerberOutputs (filmNames)
     let((cmd)
      axlSaveDesign()
      sprintf(cmd, "artwork%s %s.brd", buildString(mapcar(lambda((f), strcat(" -f ", f)), filmNames)), axlCurrentDesign())
      axlRunBatchDBProgram("artwork", cmd)
    Cheers Dave
  • eDave
    For part 2 try using axlfcreate and axlDBCreateFilmRec (16.1)
  • wERerABbiT
     Thanks Dave!! :D
  • vramanan
    vramanan over 17 years ago
     Hi
    This command will do the trick if you put it in a script file
    system artwork $module
    Here is another skill automation that will create a batch file to create the cad/valout/valext files
    It will also zip the  outputs in accordance to the part number requirement
    Your board file has to be saved with proper numbering pattern to have it work modify the code to suite your need
     (it will create one part number for assembly package and one for production, it also accounts for internal and external part)
    Or I can modify it if you give your part number need
    fabout_back.il
  • redwire
    redwire over 17 years ago
     Can you zip up your skill routine?  .il files are not recognized by the Cadence site. Imagine that. :)
