  3. How to keep form window Active while running scripts
  • Subscribers 163
  • Views 15706
Nagaraj Shanmu
Nagaraj Shanmu over 15 years ago
All,
I have a form created with a checkbox. When I select the checkbox it should read in color parameter file using axlShell command as below
procedure( lib_create_form()
            lib_form = axlFormCreate( (gensym) "lib.form" nil 'lib_form_action t)
            axlFormDisplay(lib_form)
); end procedure lib_create_form
procedure(lib_form_action(lib_form)
when(axlFormGetField( lib_form "color_update")
axlShell(strcat("param in ;setwindow form.parm_in ;FORM parm_in browse ;fillin " "symbolcolor.prm" ";FORM parm_in execute; FORM parm_in cancel"))
            ); end when color update
); end procedure lib_form_action(lib_form)
When axlShell command is executed to import the parameter file , myForm get closed automatically.
How to retain the form Active?
Nagaraj.
  • DE202408202727
    DE202408202727 over 15 years ago
    Hi Nagaraj,
    Add axlUIWPerm(lib_form, t) after the axlFormCreate command.
    Dave
  • Nagaraj Shanmu
    Thanks Dave. Worked well!!
    Appreciate your help.
    Nagaraj.
