  3. How to change net name in PCB without rerouting
  • Subscribers 162
  • Views 18298
AName
AName over 5 years ago
Is there a way to change net name in OrCAD PCB Designer 17+ without unrouting and rerouting the traces?
In Edit -> Net Properties, by right clicking the nets from the list, there is a Rename option but it's always inactive.
In earlier versions there was a command: editChangeNet, but it's no longer available.
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    Look at the documentation for the 'net logic' command, which you have to enable by with the 'logic_edit_enabled' setting
  • redwire
    redwire over 5 years ago
    Why bother changing?  If you bring in a new netlist with the existing routes that have not changed, Allegro will update the design and not rip up the copper.  Depending on the netlist update settings you can keep copper in place or remove it.  I would highly recommend against forcing a netlist change with logic-edit.  That will cause the schematic and brd file to go out of sync.
  • steve
    steve over 5 years ago
    Logic editing (net Logic) is only available with an Allegro PCB Designer license or above, it's not there using OrCAD Std or Pro.
  • AvengerThanos
    AvengerThanos over 5 years ago
    If you are using 17.4V then use the design sync option. Update the netname in schematics and use design sync feature to quickly update the changes on schematics without re-routing/unrouting
