  3. Some holes don't show up in .DRL artwork
  • Subscribers 166
  • Views 3698
jtw385
jtw385 over 4 years ago
I've just completed a design in PCB Designer 17.4 that when viewed using gerbv is flawless except for the fact that four through-holes won't show up in the .drl artwork, each corresponding to one of four pins on the same connector. These pins are connected to a ground plane on layer 2 (four layer board) and all other through holes on the board are displayed normally--even two holes on the same connector that aren't associated with these four pins. I've inspected the pad and it correctly shows oblong slotted holes on each pin. What gives?
John
  • steve
    steve over 4 years ago
    So if these are slots and not holes then you will need to use the NC Route to export this data. Slots have never been part of the NC Drill command. It's a separate file that you can send to the fabricator.
  • KeithP
    KeithP over 4 years ago
    The missing holes are slots therefore they do not appear in the NC Drill file.
    You need to create a separate NC Route file to get these holes. Manufacture -> NC -> NC Route.
  • Maximillian Kris
    Maximillian Kris over 4 years ago
    In an active PCB document, click File » Fabrication Outputs » NC Drill Files. The output will be generated immediately upon clicking OK in the dialog
    geometry dash
