  3. Right Angle Route/Slot in Padstack?
  • Replies 9
  • Subscribers 162
  • Views 5888
melview1
melview1 over 4 years ago
I'm looking for advice on how to create an odd shaped padstack for some mounting pads on a USB connector (see top 2 mounting pads in picture).  It's a plated slot/route that has a right angle and the pad is the same shape.  The pad shouldn't be that hard to do with the "shape symbol" option for the pad layers, but the drill has me at a loss as to the best way to do it.
Thanks.
  • excellon1
    excellon1 over 4 years ago
    There is no provision to do Path Operations for routing boards in the Cadence tool so you will have to go another route instead.
    Create the pad using a shape on all layers you need. Inside the pad you could do a void to represent what the actual slot will look like.
    Call out on your Fab Drawing what you wish to have routed out. At the board house what they will do is basically create a path for a specific bit so your board can be routed out.
    Hope this helps.
  • eDave
    eDave over 4 years ago
    I have found that the best way to do this is with two pins:
  • steve
    steve over 4 years ago
    You could always draw the outline of the slot using Board Geometry / Cutout then on the inside draw the actual route path using Board Geometry / NCRoute_Path. Make sure this line is drawn at the actual thickness of the slot required. Also ensure you have keeppout areas drawn to keep the slot clear of copper / tracks etc. When you post process the NCRoute_Path is included in the Manufacture - NC - NC Route file.
    • Vote Up +2 Vote Down
  • melview1
    melview1 over 4 years ago in reply to eDave
    I think I'm going to go this route.  It creates a DRC, but otherwise, is the most straight forward and least likely to get messed up in manufacturing.  Thanks for the tip Dave!
  • excellon1
    excellon1 over 4 years ago in reply to steve
    Steve, thanks for that been along time since I used that "Foggy Memory" Slight smile
    This works great. Verifying in a cam editor produces excellent results.
    In the pic you can see the results of a test route in a copper pour. The area in red is the actual tool that would route out the board to create the slot.
    This particular example just had a 50 mil curved line on the board geometry NC Route path layer. So yep lots of possibilities to pretty much route out any pad or area etc.
    Thanks.
