  3. Initial PCB layout flow using Allegro PCB Editor
  • Subscribers 158
  • Views 8852
PCBTech
PCBTech over 3 years ago
The Printed Circuit Board (PCB) is the most critical component in any electronic product as it connects all the ICs and passive components that make a final electronic product. Different companies follow different workflows for designing PCBs, starting from capturing the schematic to releasing the Gerber out for the manufacturing.
You can find a document containing information on the initial PCB Design Creation flow using Allegro PCB Editor by clicking here.
The document outlines the initial steps used to create a PCB, including padstack generation, symbol creation, import of design parameters, import of netlist and technology files, and set up of the design cross-section.
Team PCBTech
Cadence Design Systems
