  3. Skill - access to pins List
  • State Verified Answer
  • Answers 1
  • Subscribers 19
  • Views 10000
soll
soll over 4 years ago
I am learning to use Skill language to develop scripts to automate some tasks on Cadence Allegro. As a training, I am trying to write a simple script that asks the user to select a symbol, and then the script lists all the pins on that symbol alongside the net name associated with the pin. I am using this very good serie of videos on the Cadence Youtube channel : https://youtu.be/bzXmQYvpCFc
I have some issues understanding how the different interactions between the design, the database and the language itself work. I have these two pieces of code :
axlSetFindFilter(?enabled list("noall" "symbols") ?onButtons list("noall" "symbols"))
axlSingleSelectPoint()
symb = axlGetSelSet()
length(symb~>pins)  -> RETURNS 1
pinsList = nth(0 symb~>pins)
length(pinsList) -> RETURNS THE CORRECT AMOUNT OF PINS
allDBids = axlDBGetDesign()
symb2 = nth(100 allDBids~>components)
length(symb2~>pins) -> RETURNS THE CORRECT AMOUNT OF PINS
As you can see, in the first code, I trigger a selection (forcing it to symbols), then get the result of that selection in a variable (symb), then asks what is the length of the "pins" list. It returns 1, whatever symbol I pick. To get a list with 1 pin per list element, I have to use the nth() function as shown above.
In the second code, I get the design DBids, then pick one (random) symbol in the list, and asks for the length of the "pins" list. It give the correct amount of pins right away.
Does anyone has an idea about what causes the symb~>pins list to have only one element (that is, in fact, the pins list itself) whereas symb2~>pins works as expected ? Maybe I am wrongfully using the axlSingleSelectPoint() function ?
Something I may add : When I try to use -> instead of ~> to access the lists, it returns nil everytime in the first code, but it does work with the second code, and I have absolutely no idea why.
Is there some place where I could find resources about Skill ? Do you know about some forum (else than this one that I don't want to pollute) or facebook group or anything where people discuss about this language ?
Thank you for taking the time to read this, and please excuse English, it isn't my primary language.
  • mahimag
    mahimag over 4 years ago +1 suggested
    length(symb~>pins) this is returing 1 because the outout of symb~>pins is a list of list. For ex: a= symb~>pins will store ((dbid:000001778BC01148 dbid:000001778BC02038 dbid:000001778BC019C8 )) something…
  • B Bruekers
    B Bruekers over 4 years ago +1 verified
    One tip, look at each API what the possible return values are. This will save you a lot of headaches... Most of them you can find back in the Allegro SKILL Reference document. (see help documents) From…
  • B Bruekers
    +1 B Bruekers over 4 years ago
    From the API description of axlGetSelSet() :
    lo_dbid List of figure dbids.
    nil Select set is empty.
    So it always returns a list when something is selected. Even in the case if only 1 item is selected.
    Each entry in 'symb = axlGetSelSet()'  is a symbol database ID. This symbol ID contains a list, a so called disembodied property list (DPL). This is basically a list of names and values.  For example a name in the Allegro symbol DPL is 'pins'. You can find all entries in the 'The Allegro PCB Editor Database User Model'  chapter in Allegro SKILL Reference documentation.
    A basic LISP operation to get the 1st element of a list is car()
    With the '->'  you can access a variable inside a DPL  It returns a single item which can be any valid variable type (list, float, string, etc)
    With '~>'  iterates over a list of items and tries to return the value of the given name. It returns a list containing the values which are inside the requested name
    So;
    symbols = axlGetSelSet()   returns a list of selected symbol(s)
    symb = car(symbols)  ; get first item from list
    pins = symb->pins ; is a list of pins. Each pin is a database ID. So the list looks like this: (dbid1 dbid2 dbidn)
    length(symb->pins)  ; returns pin count, same as length(pins) since 'pins' was set to symb->pins
    By using symbols~>pins  you will get a list containing lists of pins.  If there was only 1 symbol selected then the length(symbols~>pins) returns 1, since there is only 1 'pin list'
    Do you want to iterate over all symbols:
    foreach(symb symbols
     pins = symb->pins
     println(length(pins))
    This is because you assigned symb2 to the 100th item in the list of symbols. The ~> instead of -> in this case is working since the 'pins' itself is a list.  However i suggest not to use ~> in any case, unless you are certain that you can not do without it.
    Some small exercise:
    axlDBGetDesign()->components                  Returns a list of component dbids
    axlDBGetDesign()->components->pins             does not work. There is no single 'pins' property name inside the list of components.
    axlDBGetDesign()->components->pins~>number  Same as above, component->pins returns nil, so no single 'number' property can be accessed.
    axlDBGetDesign()->components~>pins->number  does not work. list with pin lists does not have a single property name 'number'
    axlDBGetDesign()->components~>pins~>number  returns a list with lists of pin numbers
    Difference between ->components and ->symbols:
    axlDBGetDesign()->components  contains all component instances imported from the netlist. No physical data like location, rotation etc.
    axlDBGetDesign()->symbols contains all placed symbols instances in the PCB, so also the location, rotation etc.
  • B Bruekers
    So;
     pins = symb->pins
  • soll
    0 soll over 4 years ago in reply to B Bruekers
    Thank you for taking the time to reply !
    OK, it now makes sense that I only have one item in the first code : axlGetSelSet doesn't return the object selected, but a list of objects ; in this case, a list with 1 element... That is clear now.
    You mention the chapter "The Allegro PCB Editor Database User Model" in Allegro SKILL Reference documentation. May I ask where I could find this document ? In Allegro's installation directory, there are a few documents but none of them has that chapter, and when I search the web, I mostly find the same documents, plus some other about functions that are only working within Virtuoso or with Framework II (not sure what that on is).
    Ok so -> gives you access to what we could compare to a "pointer" in C whereas ~> only gives you the value of the item, but is not linked to it directly ? Or am I completely wrong ?
    Anyway, I rearranged the code to something that looks more like what you wrote and now -> works ! I am not sure exactly why but it is already a good step :p
    Thank you a lot for the exercises, I will try fiddling around with those tomorrow morning.
  • soll
    I have found the Allegro User Guide: SKILL Reference. It is perfect ! To anyone who might be searching : I found it by searching an axl function (axlPinsOfNet in that case) in the search menu of the Help Tab (Allegro), then by clicking on the "Allegro SKILL Reference" in the Document Name tab of the search window. Once the document is open in the search window, there is a PDF icon in the tool bar that let you access it.
