  3. Allegro - Tip of the Week: Do you know that you can have...
  • Replies 7
  • Subscribers 167
  • Views 9783
Allegro - Tip of the Week: Do you know that you can have your design autosaved at regular intervals?
PCBTech
PCBTech over 4 years ago
You can set the autosave feature in your design, which helps in saving your work periodically. The key variables to autosave the database are present under the File_management section in User Preferences Editor. You can open this using Setup > User Preferences.
  • autosave: Set to enable autosaving
            This option must be set before starting the layout editor.
  • autosave_dbcheck: Set to run a quick database check before an autosave
            By default, this option is turned off to save time. It requires a restart.
  • autosave name: Specifies the base name for the autosave file
           The default name is AUTOSAVE. Do NOT provide a file extension. The layout editor will use the appropriate extension based on the type of database under edit. It requires a restart.
  • autosave time: Specifies the autosave intervals
            The default time is 30 minutes. The minimum is 10 minutes, and the maximum is 300 minutes. It requires a restart.
Team PCBTech
Cadence Design Systems
  • Schulz Jordan
    Schulz Jordan over 3 years ago +1
    There are 2 challenges here 1. The minimum save time is 10min and in many cases it may not be sufficient. Are there any future updates planned to reduce the minimum save time ? 2. As the other user…
  • Jeff H
    Jeff H over 3 years ago in reply to PCBTech +1
    I would put a second vote for being able to set a location for the autosave files.
  • Micheal schenk
    Micheal schenk over 4 years ago
    For instance, a user works for 8 hrs and save time given to 20 min. By the end of the time, there would be 24 copies. Is there a way where only the last 3 backups can be saved and the rest all are auto-deleted? which would reduce space and also confusion.
  • PCBTech
    PCBTech over 4 years ago in reply to Micheal schenk
    use variable ads_autosaverevs and specify the number of versions you want to maintain for AUTOSAVE database files.
    You can find this variable in Setup > User Preferences > File management > Versioning
  • PCBDsgnr
    PCBDsgnr over 3 years ago
    Can the location of autosave be set to a fixed path? For example, the design location is a far away network drive, a 100mb design will take long to save with every autosave, interrupting workflow.  Could the autosave be set to a location on C drive?
  • masamasa
    masamasa over 3 years ago in reply to PCBDsgnr
    i think the autosaved files can be located at no other locations but in your working directory only. if u need the autosaved files to be found in the c drive, the working directory of your design needs to be in the c drive as well.
  • Schulz Jordan
    2. As the other user mentioned there should be an option where the user can define the path where to save the files.
    FYI: Other popular EDA tool has both above mentioned features.
