  3. Coil Designer Error
  • State Suggested Answer
  • Answers 1
  • Subscribers 160
  • Views 8145
Coil Designer Error
PCB6453
PCB6453 over 2 years ago
Hello All,
I was using the Coil Designer with no issues.  Now, it is giving me an error when I try to use the feature.
*Error* parseString: argument #1 should be either a string or a symbol (type template = "SSg") - nil
Once I got the error message, I decided to try it out on the design file a few days before and had no issues.  The only main change I did on the design is reducing the layer count.  I assume that this is what caused the problem.
Anybody encountered this issue?  And hopefully found a solution?
thanks,
PCB6453
  • JuanCR
    0 JuanCR over 2 years ago
    Try this solution:
    Saving and reloading the film records may resolve the problem.
    1. To save the film records
       a. Select Manufacture > Artwork - Film Control tab
       b. Select all film records
       c. Right Mouse Button and choose "Save All Checked"
    2. To load the film records
       b. Click on 'Load...'
       c. Select 'FILM_SETUP.txt' file
    If the issue persists, you will have to delete and recreate the film records.
  • PCB6453
    0 PCB6453 over 2 years ago in reply to JuanCR
    Thank you for your suggestion.  I had to get the board out and I just created the coil pattern on the design file that didn't have any issues.  From there, I exported the subdrawing and placed it in the current design file.  Once I did that, I didn't run into anymore issues.
