  3. How to find pin name using SKILL
  • State Suggested Answer
  • Answers 1
  • Subscribers 22
  • Views 5276
fithawi
fithawi over 3 years ago
Hi there
How can I find the logical pin name of a symbol using SKILL?
The script below can find the Padstack Name, XY location of the pin, and Pin number. However, I am getting the wrong value for the pin name.
procedure(Diff_Pin_Net()
  prog(( Pin_Log_File padStackN pinName pinNumber pinx piny)
   ; Open the log file and print the header info
   Pin_Log_File = outfile("./dummy_net_list.log" "w")
   fprintf(Pin_Log_File "\tDummy net logfile\n\n\n")
   fprintf(Pin_Log_File "\tTotal dummy pin: %L\n\n" length(axlDBDummyNet('pin)))
   fprintf(Pin_Log_File "\t%s\t\t%s\t\t%s\t%s\n\n\n" "Padstack Name" "---XY---" "Pin Name" "Pin number")
    foreach( mapc x axlDBDummyNet('pin)
    padStackN = x->name
    pinName = car(car(x)->functionPins)->name
    pinx = car(x->xy)
    piny = cadr(x->xy)
    fprintf(Pin_Log_File "\t %s \t(%.3f %.3f)\t%L\t\t%s\n\n"  padStackN pinx piny pinName axlDbidName(x)))
   ; Highlight the dummy pins
   axlClearSelSet()
   axlCustomColorObject(axlDBDummyNet('pin))
   ; Close the log file, refresh the graphics, and open a viewlog
   close(Pin_Log_File)
   axlShell("redisplay")
   axlShell("viewlog ./dummy_net_list.log")
  );end prong
  ); end procedure
  • AsbjornEdvalds
    AsbjornEdvalds over 3 years ago in reply to JuanCR +1 suggested
    Hi both, I also reviewed this code snippet, and the issue seems arise at the mapc function in the foreach loop. Using the mapc lets the foreach function iterate over each element of the argument list…
  • JuanCR
    0 JuanCR over 3 years ago
    Hey fithawi
    I checked your code and I have these comments for you:
    fithawi said:
    padStackN = x->name
    This line doesn't look right ... I believe it should be car(x)->name
    This line I can confirm is right. And I believe this is the one that you're looking for.
    Just as an example, I tested it on the Cadence Demo board and got this:
    If you're not getting the right pin name, maybe the error is somewhere else in your design? Let me know if you still have trouble with this. Maybe I can contact you via a private message and discuss it.
  • AsbjornEdvalds
    0 AsbjornEdvalds over 3 years ago in reply to JuanCR
    Hi both,
    Using the mapc lets the foreach function iterate over each element of the argument list. There is therefore no need to do a car(x)->something since x is a single item from the axlDBDummyNet('pin) list.
    By changing the pinName = car(car(x)->functionPins)->name to pinName = car(x->functionPins)->name the whole function works as intended.
