  3. Database diary journal
  • State Suggested Answer
  • Answers 1
  • Subscribers 159
  • Views 7282
DBTCH
DBTCH over 2 years ago
Hi All ,
Somebody know if there is a way to check if the database diary journal is not empty with Skill command ?
I would like to open the diary journal at the opening database if the journal contain some information .
Best regards
  • B Bruekers
    0 B Bruekers over 2 years ago
    Afaik it is stored as an attachment.
    att = axlGetAttachment("db_diary.txt" 'string)
    l_string = parseString(att->data "\n\r")
  • revida marcos
    0 revida marcos over 2 years ago
    Good day!
    There are a few different approaches you can take if you want to use a Skill command to determine whether the database diary journal is empty. Using a conditional statement to see if the journal has any entries is one straightforward method. You may, for instance, employ the following "IF" statement:
    IF diary_journal NOT EMPTY
    // Open the diary journal
    ENDIF
    To put it simply, this code means "If the diary journal is not empty, then open it." You can tell if the journal has information by examining if the diary_journal variable is not empty.
    To reflect your actual database diary journal, replace "diary_journal" with the proper variable or command.
    Hope that was useful. Regarding your database journal, good luck!
  • DBTCH
    0 DBTCH over 2 years ago
    Thank you for your answers,
    your answers confirm what I thought.
    I need to export to a text file first and if there are no records there is no db_diary.txt created, so just test if the file exists.
  • B Bruekers
    0 B Bruekers over 2 years ago in reply to DBTCH
    Don't get confused with the name 'db_diary.txt'.  It is not a text file but an attachment in the BRD file.
    So there is no need to export anything, just check if the attachment is present and contains something.
