  3. How to display top and bottom pads through inner layers...
  • State Suggested Answer
  • Answers 1
  • Subscribers 160
  • Views 7360
How to display top and bottom pads through inner layers?
Farco
Farco over 2 years ago
Whenever I display inner layers, the pads in top and bottom layers cannot be seen. How can I fix this?
Regards.
  • avant
    0 avant over 2 years ago
    Go to the color dialog box to set colors for the inner layers. It looks like they are set to black.
  • mcatramb91
    0 mcatramb91 over 2 years ago
    It looks like Layer GND1 is a Negative Plane so you are seeing the Anti-Pad and Thermal openings in the Shape, which are blocking out the Top and Bottom Pads.
    If you disable Thermal pads under Design Parameters > Display Tab (Setup > Design Parameters) you will see Top and Bottom pads again.  I normally enable Thermal Pads when I am reviewing Negative Planes only and leave it off most of the time.
    Hope this helps,
    Mike Catrambone
