  3. Constrain Manager: LayerSubTypes.xml could not be read
  • Replies 8
  • Subscribers 160
  • Views 8268
toldav
toldav over 2 years ago
I'm having some issues with constrain manager and I'm trying to figure out why I'm getting this error.
OS = RHEL7.9
SPB174
Constrain Manager
CDS_SITE-specific configuration file LayerSubTypes.xml could not be read - see log for details
Here is the permission below
ls -l /tools1/SPB174/share/local/consmgr/LayerSubTypes.xml
-rwxr-xr-x 1 root ads 780 May 1 2016 /tools1/SPB174/share/local/consmgr/LayerSubTypes.xml
Problems encountered while reading "" Read: Wed Jun 14 17:08:06 2023
Error: unable to open primary document entity '' (l:0; c:0)
Section read operation aborted
Thank you
  • VVRD
    0 VVRD over 2 years ago
    Hello toldav,
    Create CDS_SITE using the article
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nbz9EAA
    Copy LayerSubTypes.xlm from installation folder.
    Thank you.
  • toldav
    0 toldav over 2 years ago in reply to VVRD
    Hi VVRD,
    Do you know where should I copy the file to? I'm little confused about this.
    here is the source:
    $ ls -l /tools1/SPB174/share/local/consmgr/LayerSubTypes.xml
    Thank you for your feedback
    toldav
  • VVRD
    0 VVRD over 2 years ago in reply to toldav
    can you try copying in the PCB folder you created in step 3 of the link I shared?
  • toldav
    I'm trying figure it out where to copy since our system is Linux.
    our path is /application/pcb
    I will follow up with you if that works tomorrow.
    Thanks again for your help
    toldav
  • VVRD
    Are you able to solve the issue?
    Thank you.
