  3. dxf out question
  • Replies 11
  • Subscribers 159
  • Views 10265
dxf out question
masamasa
masamasa over 2 years ago
hello
is there a way to maitain the assigned color on the bga pads on the design during the dxf export?
the exported dxf file has always white colored pads.
regards
masa
  • VVRD
    0 VVRD over 2 years ago
    Are you able to export Pin class, Top/bottom subclass layer to DXF file?
  • masamasa
    0 masamasa over 2 years ago in reply to VVRD
    i can export the pin class but the color assigned on the pins disappears during the dxf export.
  • GilMay2
    0 GilMay2 over 2 years ago
    Hi Masa,
    I'm using SPB v17.4 S036.
    There is Color Mapping option in DXF Out setup to match database colors.
  • masamasa
    0 masamasa over 2 years ago in reply to GilMay2
    thank u for ur comment.
    the color mapping option is already set as "match database colors" as default but the exported dxf file has all white.
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to masamasa
    I just tested this with allegro 22.1 S006 & the colors were output correctly...
