  3. Converting .MAX file to .BRD File issue
  • State Suggested Answer
  • Replies 12
  • Answers 3
  • Subscribers 162
  • Views 10551
greekwonder
greekwonder over 2 years ago
I'm trying to convert a max file into a brd file, currently running v22.10.006.
An error message pops up saying "....filename.log' does not exist."
I've used this method (Import -> CAD Translators -> OrCAD Layout) before using v17.4 of the cadence tool.
For some reason, with the latest version, it requires a log file that I've never needed before.
Has anyone else run into this issue?
  • John T
    0 John T over 2 years ago
    Is there any error code associated with this message? Please also confirm if you have the opportunity to regenerate this .MAX file. It would be prudent to run a database clean-up  (Auto -> Clean Up). Also, check for split planes and try converting these plane layers to routing layers.
  • greekwonder
    0 greekwonder over 2 years ago in reply to John T
    No error code is associated with this message.
    Unfortunately I don't have access to the legacy software used to regenerate this file. the earliest version I have access to is Allegro PCB Editor 16.6.
  • John T
    0 John T over 2 years ago in reply to greekwonder
    We have contacted you by email in order to assist you with this issue.
    • Vote Up +2 Vote Down
  • BTerry
    0 BTerry over 1 year ago in reply to John T
    I have the same issue where rather than translating the file I get the message .filename.log does not exist. if I could get some information regarding potential solutions,
  • John T
    0 John T over 1 year ago in reply to BTerry
    Hi BTerry, apologies for not seeing your comment earlier. My understanding is that the user managed to get this to work by themselves. I requested more details but haven't heard back. If you could send me this design I could attempt the conversion for you if you could supply your email address for this.
