  3. Converting .MAX file to .BRD File issue
  • State Suggested Answer
  • Replies 12
  • Answers 3
  • Subscribers 167
  • Views 14056
greekwonder
greekwonder over 3 years ago
I'm trying to convert a max file into a brd file, currently running v22.10.006.
An error message pops up saying "....filename.log' does not exist."
I've used this method (Import -> CAD Translators -> OrCAD Layout) before using v17.4 of the cadence tool.
For some reason, with the latest version, it requires a log file that I've never needed before.
Has anyone else run into this issue?
  • John T
    John T over 3 years ago in reply to greekwonder +2 suggested
    We have contacted you by email in order to assist you with this issue.
  • greekwonder
    greekwonder over 2 years ago in reply to BTerry +1 suggested
    Hi BTerry, apologies for the late reply. I ended up moving the files into a folder with a proper structure and somehow that fixed the issue. It's possible that something in the previous folder was corrupted…
  • DavidAhl
    DavidAhl over 1 year ago in reply to DavidAhl +1
    got it to work, ran orcad as administrator and copied the whole folder to C:\ then ran db doctor.
  • John T
    0 John T over 2 years ago in reply to John T
    Hi BTerry, in fact I have already sent you a friendship request to enable us to exchange files. Please check and accept in order to work on this further together.
  • greekwonder
    0 greekwonder over 2 years ago in reply to BTerry
    It's possible that something in the previous folder was corrupted or not seen properly is my guess. Let me know if that works for you!
  • DavidAhl
    0 DavidAhl over 1 year ago in reply to John T
    I have the exact same issue as BTerry with the missing filename.log.
    Has there been found a method to solve the issue?
    best regards
  • DavidAhl
    0 DavidAhl over 1 year ago in reply to DavidAhl
    got it to work,
  • John T
    0 John T over 1 year ago in reply to DavidAhl
    Thanks for sharing David!
