  3. Converting .MAX file to .BRD File issue
  • State Suggested Answer
  • Replies 12
  • Answers 3
  • Subscribers 167
  • Views 14065
greekwonder
greekwonder over 3 years ago
I'm trying to convert a max file into a brd file, currently running v22.10.006.
An error message pops up saying "....filename.log' does not exist."
I've used this method (Import -> CAD Translators -> OrCAD Layout) before using v17.4 of the cadence tool.
For some reason, with the latest version, it requires a log file that I've never needed before.
Has anyone else run into this issue?
  • John T
    John T over 3 years ago in reply to greekwonder +2 suggested
    We have contacted you by email in order to assist you with this issue.
  • greekwonder
    greekwonder over 2 years ago in reply to BTerry +1 suggested
    Hi BTerry, apologies for the late reply. I ended up moving the files into a folder with a proper structure and somehow that fixed the issue. It's possible that something in the previous folder was corrupted…
  • DavidAhl
    DavidAhl over 1 year ago in reply to DavidAhl +1
    got it to work, ran orcad as administrator and copied the whole folder to C:\ then ran db doctor.
  • SM202509306927
    0 SM202509306927 over 1 year ago
    I am having the same issue as this user describes. I don't have access to ORCAD to run DB doctor. When I run "orcad in" from Allegro PCB designer, I get a number of .txt files output but no .brd
  • SM202509306927
    0 SM202509306927 over 1 year ago in reply to SM202509306927
    I've identified that my issue was specific to 23.1 Allegro PCB Editor. When I ran "orcad in" in 17.2, I did not have the same issue. Thanks
