  3. The net name not appearing properly
  • State Suggested Answer
  • Answers 1
  • Subscribers 160
  • Views 7270
Ram1234
Ram1234 over 2 years ago
Hi Team,
Good day!,
I have added the power VCC_BAR  symbol in sch and renamed as VCC_3V3.
After the change of the name, the net name(wire name) is to be VCC_3V3, but it was not changed.
It is showing as VCC_BAR, why?
I have deleted and added new, did the same , but no changes.
GND is fine , it is showing as GND in wire.
so please help me out to solve this isues.
  • Robert Finley
    0 Robert Finley over 2 years ago
    I suspect this is on a sub-level of a hierarchy design.  Do you have a net "VCC_BAR" through a hierarchy port on the top level?
    This is the practice I use.  3v3 pwr net for a circuit sub-block has a specific net name.
    I count on the top level of the hierarchy to override/connect them together and be easily verified.
  • Ram1234
    0 Ram1234 over 2 years ago in reply to Robert Finley
    Hi Robert Finley,
    Good day!,
    Can you please expalin in detail to understand more.
    Ram.
  • Robert Finley
    0 Robert Finley over 2 years ago in reply to Ram1234
    A lot of my projects are hierarchical, a mix of old and new blocks.
    I built an example DSN file to demonstrate, shared from my public GitHub account.
    Using a web-browser, go to GitHub.com and add the following:
    <github website> RobertFinleyPublic/RFinleyPublic2
    Top level of the hierarchy is called Page1.  Page 1a is the sub-block.
    Properties on page1a, net names from the top-level of the hierarchy (page1) are overriding both power and gnd global nets on the sub-block.
    Net names NOT_SYS_5V and SIGNAL_GND are overwritten by the top level, through the rectangular hierarchy block connectors.
    Hierarchical connector blocks named SYS_5V and SYS_GND have no impact on the netlist as far as I know.
    I encourage my engineers to add global net symbols for readability so I don't have a ratsnest of power/gnd wiring on the schematic.
    As long as we use unique (global) vdd net names on sub-blocks, this practice has sharply reduced the power rail netlist errors we had.
