  2. PSpice
  3. How to solve this problem in simulation?
  • Subscribers 32
  • Views 16374
qqplasm
qqplasm over 6 years ago
Here is the model code:
* PSpice Model Editor - Version 17.2.0
.SUBCKT Cj NP NN
.PARAM C0=2.1E-13
.PARAM V0=2.7
.PARAM a=0.7
.PARAM ISS=56.19E-6
.PARAM Vb={a*V0}
.FUNC Csc(X) {IF(V<Vb,C0/SQRT(1-V/V0),C0*SQRT((1-a)^3)*(1-1.5*a+0.5*V/V0)}
***** BEGIN CIRCUIT *****
*SCH SECTION
.MODEL DSCH D (IS={ISS} N=2 RS=0.45)
DS NP NN DSCH
GCsc NP NN VALUE={Csc(V(NP)-V(NN))*DDT(V(NP)-V(NN))}
.ENDS
Here is my simulation proble:
*** FROM LIBRARY ../../../cj.lib ****
.SUBCKT Cj NP NN
.PARAM C0=2.1E-13
.PARAM V0=2.7
.PARAM a=0.7
.PARAM ISS=56.19E-6
.PARAM Vb={a*V0}
*SCH SECTION
ERROR(ORPSIM-16367): End of expression not seen
DS NP NN DSCH
DS NP NN DSCH
.ENDS
ERROR(ORPSIM-16499): Missing .ENDS in .SUBCKT
Can anyone help me with this problem for my simulation? Many thanks!!
  • oldmouldy
    oldmouldy over 6 years ago +1
    Your function is likely invalid. "^" in PSpice expressions is Boolean XOR, I suspect that you actually need PWR, or PWRS, to raise a variable by a power. (See the PSpice Users Guide) Also, your Csc function…
  • oldmouldy
    0 oldmouldy over 6 years ago
    Your function is likely invalid. "^" in PSpice expressions is Boolean XOR, I suspect that you actually need PWR, or PWRS, to raise a variable by a power. (See the PSpice Users Guide) Also, your Csc function has an X parameter "passed in" but X isn't used anywhere in the function expression.
  • qqplasm
    0 qqplasm over 6 years ago in reply to oldmouldy
    I modified the model based on your advice:
    .SUBCKT Cj NP NN
    .PARAM C0=2.1E-13
    .PARAM V0=2.7
    .PARAM a=0.7
    .PARAM ISS=56.19E-6
    .PARAM Vb={a*V0}
    .FUNC Csc(X) {IF(X<Vb,C0/SQRT(1-X/V0),C0*SQRT((1-a)*(1-a)*(1-a))*(1-1.5*a+0.5*X/V0)}
    *SCH SECTION
    DS NP NN DSCH
    .ENDS
    But the result still the same:
    **** FROM LIBRARY ../../../cj.lib ****
    .SUBCKT Cj NP NN
    .PARAM C0=2.1E-13
    .PARAM V0=2.7
    .PARAM a=0.7
    .PARAM ISS=56.19E-6
    .PARAM Vb={a*V0}
    *SCH SECTION
    DS NP NN DSCH
    DS NP NN DSCH
    .ENDS
    I did put .ENDS in the end of the model and the expression is complete. Could you help me with this problem?
  • qqplasm
    I modified the model base on your advice.
    But the simulation result is exactly the same.
    I did put an .ENDS in the end of the model and the expression is complete. I don't understand why the errors keep show up. Could you please help me with the problem?
  • oldmouldy
    0 oldmouldy over 6 years ago in reply to qqplasm
    The IF statement is missing a closing bracket at the right hand side.
