  2. PSpice
  3. wrong MOSFET characteristic
  • Subscribers 32
  • Views 13515
Gigilatrottola
Gigilatrottola over 6 years ago
Hi, I would like to understand why I can't correctly display the characteristic of a level 3 SPICE model MOSFET.
This is the setting with the characteristic.
Thanks for your availability
  • oldmouldy
    oldmouldy over 6 years ago +1
    What are you expecting to see? The plot is correct for the settings that you have, the X-Axis is the Primary Sweep, the Y-Axis is the value of I(M1:drain) and there is one curve for each of the three values…
  • Gigilatrottola
    Gigilatrottola over 6 years ago in reply to oldmouldy +1
    I don't understand the trend in the triode region. The trend of a common MOSFET is not that. As for the level 1 SPICE models I don't have this problem, the simulation has the typical trend of MOSFETs.…
  • oldmouldy
    0 oldmouldy over 6 years ago
    What are you expecting to see? The plot is correct for the settings that you have, the X-Axis is the Primary Sweep, the Y-Axis is the value of I(M1:drain) and there is one curve for each of the three values in the Value List of the Secondary Sweep.
  • Gigilatrottola
    0 Gigilatrottola over 6 years ago in reply to oldmouldy
    The trend of a common MOSFET is not that. As for the level 1 SPICE models I don't have this problem, the simulation has the typical trend of MOSFETs. But I would like to use level 3 models which take into account further effects. Is this the correct setting to operate a level 3 model?
