  2. PSpice
  3. How to enlarge the probe cursor data window
  • Subscribers 32
  • Views 14907
Pharos
Pharos over 6 years ago
I'm using Orcad Capture Lite and once a circuit is simulated and the Graphical simulation window opens I can turn on the Cursors, get the cross-hair cursors and the X Axis and Y Axis values appear in a separate window below the main graphical window. However these data values are very small even on good size monitor. In the older version of PSpice I used to use the graphical data values appeared as a movable box on the graphical window and were very clear to see. Can the data value window be enlarged?
  • AvengerThanos
    AvengerThanos over 6 years ago +1
    Select a column in the data values window. Hold ctrl+MMB to zoom in or zoom it to get a comfortable view
  • Pharos
    Pharos over 6 years ago in reply to AvengerThanos +1
    Cor Blimey it works many thanks Avenger
  • AvengerThanos
    0 AvengerThanos over 6 years ago
  • Pharos
    0 Pharos over 6 years ago in reply to AvengerThanos
