  2. PSpice
  3. ua741 integrator in negative domain
  • Subscribers 32
  • Views 14778
devesh Kadambari
devesh Kadambari over 6 years ago
This an integrator circuit of the opamp UA741 which I`m trying to get the results of but when i look at the results they are far more off than what i was expecting them to be . The results from the integrator is just acting in the negative domain of the opamp which im not understanding. Also, at the output i have kept a diode with a voltage of 1v which is supposed to be working as a piece wise function of the {Vs vin>0; 1 vin<0}. but the output at the end is just 1v constant. Please let me know what the fault is? I have attached the schematic in this post . Also the results.
  • AvengerThanos
    AvengerThanos over 6 years ago in reply to devesh Kadambari +2
    The same diode mentioned in your design D1N4490
  • AvengerThanos
    AvengerThanos over 6 years ago +1
    As the input is fed to the inverting terminal the output is inverted. The output seems fine. Replace the diode as I could see output at the diode as attached.
  • devesh Kadambari
    devesh Kadambari over 6 years ago in reply to AvengerThanos +1
    which diode were you using?
  • AvengerThanos
    0 AvengerThanos over 6 years ago
  • devesh Kadambari
    0 devesh Kadambari over 6 years ago in reply to AvengerThanos
  • AvengerThanos
    0 AvengerThanos over 6 years ago in reply to devesh Kadambari
    • Vote Up +2 Vote Down
