  2. PSpice
  3. Creating and editing models
  • Subscribers 31
  • Views 16747
Mohammad Sadr
Mohammad Sadr over 5 years ago
Hi Friends
I needed an LM565 to simulate, but unfortunately, the software did not have that LM565, and I accidentally saw this code on the Internet!
But I do not know how to give this code to the software!
The code is available in the following file
8637.SUBCIRCUIT.pdf
I have another problem and that I do not know what the format code is ?! And that when I copied this code from this PDF I had to change it. Can you help me and tell me if the code in the file above is the same as the code I wrote below or not ?!
Thank You
code:
.SUBCKT LM565 1 2 3 4 5 6 7 8 9 10
C_C1 0 init 1u
R_R3 $N_0001 6 1.75k
R_R4 0 init 1g
R_R6 8 9 10g
R_R2 3 0 10g
R_R1 $N_0002 7 3.6k
E_E15 $N_0002 0 VALUE { V($N_0003, 0)+V(6,0) }
E_E1 $N_0003 0 TABLE { 0.68*V(2, 0)*V(5,0) } + ( (-0.68,-0.68) (0.68,0.68) )
G_G1 init 0 VALUE { (V(7,0)-V(6,0))*0.00001458/(R0*C0*(V(10,0)-V(1,0))) }
E_E13 4 0 VALUE {sin(6.28*(0.27/(R0*C0))*(time+(R0*C0/(6.28*0.27))*V(0,init))) }
E_E3 $N_0001 0 VALUE {0.126354*(0.7+V(1,0))+0.873646*V(10,0) }
.ENDS
    ShawnLogan over 5 years ago +1
    Dear Mohammad, Mohammad Sadr said: I have another problem and that I do not know what the format code is ?! And that when I copied this code from this PDF I had to change it. Can you help me and tell…
    Andrew Beckett over 5 years ago in reply to ShawnLogan +1
    Hi Mohammad, More importantly, knowing which tool you're actually trying to use this model in is pretty key. Given that this is a discrete component, I suspect you're probably wanting to use PSPICE,…
    Andrew Beckett over 5 years ago in reply to Mohammad Sadr +1
    OK, having seen your other post in this thread, your questions are about Orcad Capture (and hence Pspice) so I'll move this thread into the PCB Design forum as that's the best place for it. You should…
  • Mohammad Sadr
    0 Mohammad Sadr over 5 years ago in reply to Andrew Beckett
    I'm sorry, I did not realize that I had to raise this issue in the PCB section, but whatever you do, I am a newcomer.
    Since the topic was about model design and EC, I guessed this forum is better.
    In any case, I apologize.
    Well, our teacher does not give any instructions and expects us to do everything, even from 0 to 100, I did this learning with this software myself.
    Thank you dear friend
