  2. PSpice
  3. Using S-parameter within Allegro CIS?
  • Subscribers 33
  • Views 10759
bmak08
bmak08 over 5 years ago
I am trying to create a symbol that references an S-parameter file for a simulation. Is it possible to use Allegro CIS and PSPICE AD to run a simulation that requires s-parameters?
Thanks!
  • excellon1
    0 excellon1 over 5 years ago
    Hi, have a look at the following app note
    https://www.pspice.com/sites/default/files/PSpice%20App%20Note_Obtain%20S-Parameter%20Data%20from%20the%20Probe%20Window.pdf
    This may be of help.
  • bmak08
    0 bmak08 over 5 years ago in reply to excellon1
    Hi, thanks for the app note.
    To be clear, I am not trying to create / define S-parameters of a model. I have an existing S-parameter model that is defined and would like to run a simulation in PSPICE AD. Is there any way to simulate this?
    Thanks!
  • excellon1
    0 excellon1 over 5 years ago in reply to bmak08
    The S-Parameter data you have is just the result of a simulation of reflection measurements for a device. For passive devices this would be impedance data vs frequency, Mag Phase etc. For active devices such as a transistor etc this would be the measured impedance data at a fixed bias point.
    It would be possible to do what you are after to some degree but in p-spice you would need to create a sub-circuit for analysis and pull the manufacturers SP2 data into that. "Not easy to do"
    Here is an older app note that goes into that.
    https://designers-guide.org/forum/Attachments/CreateS-ParameterSUBCKTinPSpice.pdf
    A far better way do analysis on SP2 data you would be to use a dedicated RF simulator such as ADS or AWR.
