  2. PSpice
  3. PSpice - Tip of the Week: Want to compare different waveforms...
  • Subscribers 30
  • Views 2039
PSpice - Tip of the Week: Want to compare different waveforms? Use the Append Waveform feature.
DesignTech
DesignTech over 4 years ago
Using the Append Waveform (.DAT)… feature, after the first file is loaded, you can load other files into the same Probe window. You can compare two waveforms from different simulation runs by using Append Waveform.
In pspice window ,Go to File -> Append Waveform (.DAT)…
Team DesignTech
Cadence Design Systems
