  2. PSpice
  3. Pspice error
  • Subscribers 31
  • Views 11514
Pspice error
div1
div1 over 4 years ago
I am new to OrCAD Capture.
Three components which was required for my design was not available as PSpice component. After adding the component using "Search providers", when I generate a netlist, these are the warnings shown :
WARNING(ORNET-1119): The part/device cannot be simulated. No PSpiceTemplate found on IC1, ignoring this part/device from simulation netlist. Use Place->PSpice Component...->Search to place simulation ready part
WARNING(ORNET-1119): The part/device cannot be simulated. No PSpiceTemplate found on IC4, ignoring this part/device from simulation netlist. Use Place->PSpice Component...->Search to place simulation ready part
WARNING(ORNET-1119): The part/device cannot be simulated. No PSpiceTemplate found on IC5, ignoring this part/device from simulation netlist. Use Place->PSpice Component...->Search to place simulation ready part
What can I do to fix these warnings and run my simulation?
Thanks & Regards,
Divya
  • rg13
    rg13 over 4 years ago +1
    I am giving you following link from Cadence Online support portal which has helped me many times for this particular Warning ORNET – 1119 Article (11149760) Title: Warning ORNET – 1119 "No PSpiceTemplate…
  • AyushD
    AyushD over 4 years ago +1
    Place components via Place -> PSpice Components -> Search to place pspice simulatable parts
  • rg13
    0 rg13 over 4 years ago
    Article (11149760) Title: Warning ORNET – 1119 "No PSpiceTemplate for, ignoring" while running simulation
    URL: support.cadence.com/.../ArticleAttachmentPortal
  • AyushD
    0 AyushD over 4 years ago
  • div1
    0 div1 over 4 years ago in reply to rg13
    Thank you
