  2. PSpice
  3. Linking .net file to device part shape
  • State Suggested Answer
  • Answers 1
  • Subscribers 34
  • Views 11995
TMARDTM
TMARDTM over 4 years ago
How can I link a device model that isn't a .lib file to a schematic symbol shape?
I have an EPC transistor model that is defined in a .net file and I want to link that model to an existing MOSFET symbol.
How is this accomplished? I couldn't find any documentation that instructs how to do this association.
Any pointers or an example would be greatly appreciated.
  • AyushD
    AyushD over 4 years ago +1 suggested
    .net file in pspice is a netlist file. But if you have a PSpice model, save it as .lib and then use model editor to link this lib to an existing mosfet symbol. In model editor go to File -> Model Import…
  • AyushD
    0 AyushD over 4 years ago
    In model editor go to File -> Model Import Wizard and here you can input your .lib file and provide a destination folder, then you will get the option to browse for an existing symbol to link it to you lib.
    Hope it helps
  • RaminR
    0 RaminR over 2 years ago in reply to AyushD
    I found EPC Orcad models (.olb) in Digikey website: https://www.digikey.com/en/models/16524762
  • HIMS
    0 HIMS over 1 year ago in reply to RaminR
    A .olb is a symbol file used to place the part in the schematic. I believe the .net file you have has the model definition (.model or .subckt). If so, it is a PSpice model library file. You must modify the filename extension from .net to .lib and attach this to symbol.
