  2. PSpice
  3. How to add tolerances to sub-circuit model parameters for...
  • Subscribers 30
  • Views 7826
How to add tolerances to sub-circuit model parameters for PSpice Advance Analysis
DesignTech
DesignTech over 4 years ago
Pspice Advance Analysis such as Sensitivity and Monte-Carlo Analysis are based on tolerances that are defined on the model parameters of the devices in the design.
Tolerances can be defined for any parameters of any sub-circuit model in the design via Assign Tolerance window as shown below.
Tolerances will be used in all instances In the design which use that sub-circuit model.
Check this video for detailed steps on how to add tolerances and what is tolerance distribution.
Team DesignTech
Cadence Design Systems
