  2. PSpice
  3. Error with Net Aliases
  • State Verified Answer
  • Answers 1
  • Subscribers 31
  • Views 12081
StanK
StanK over 4 years ago
I am using OrCAD PSpice Designer 17.4-2019-S030.  Recently I found that if I create a new circuit and include "Net Aliases" I get a warning message "WARNING(ORPSIM-15220): Error in opening Alias File ...." and the model does not run.  If I delete the New Aliases the model runs fine.  I can then go back and add the Net Aliases and it still works fine.
I don't recall having this issue previously and am wondering if it is a new bug.  It also did this with ISR Hot Fix S029.
Stan
  • TechiEE12
    TechiEE12 over 4 years ago +1 suggested
    Make sure none of your aliases name has a space in between. For example- If it is PWR Connector, then rename it to PWR_Connector or PWRConnector
  • StanK
    StanK over 4 years ago in reply to TechiEE12 +1 verified
    That was it. Thank you, I forgot about the no spaces allowed.
  • TechiEE12
    0 TechiEE12 over 4 years ago
  • StanK
    +1 StanK over 4 years ago in reply to TechiEE12
