  2. PSpice
  3. PSpice - Tip of the Week: Using Display Control in Probe...
  • Subscribers 30
  • Views 1266
PSpice - Tip of the Week: Using Display Control in Probe Window
DesignTech
DesignTech over 4 years ago
In PSpice you can create displays to save the contents of a Probe window. You can view a display again later with a different simulation, if the new simulation has identically named variables.
Once the display is saved, you can copy, edit or delete it.
From the Window menu, in probe window choose Display Control. The Display Control dialog box will appear.
Here you can perform any operation like save, copy or edit as highlighted below:
Team DesignTech
Cadence Design Systems
