  2. PSpice
  3. How to make Warning disappear in the simulation output file...
  • Subscribers 32
  • Views 7646
How to make Warning disappear in the simulation output file?
NancyCadence
NancyCadence over 4 years ago
Hi Expert,
I have a quick question for PSpice. Do you have any experience for this warning?
After completing the simulation, there is a warning in the simulation output file as below. The simulation result is correct.
Do you know what meaning is? How do I know if it is not a subcircuit param?  How to make this warning disappear?
The internal circuit is as below.
Thanks a lot!
Nancy
  • Schulz Jordan
    Schulz Jordan over 4 years ago
    Can share the model file (.lib) on platform. It seems the model itself might have some issue.
  • NancyCadence
    NancyCadence over 4 years ago in reply to Schulz Jordan
    Hi Schulz,
    Yes, you are right. The issue was fixed with updating the model. Thanks for your input!
    Nancy
