  2. PSpice
  3. PSpice – MATLAB Co-Simulation
  • Subscribers 31
  • Views 8403
DesignTech
DesignTech over 4 years ago
PSpice - MATLAB interface extends the PSpice visualization capabilities to the next level. In just one click, the interface allows you to export all or selected trace data to MATLAB, where you can analyze and visualize the data in an enhanced way. You can visualize simulation results on various plots, such as Polar Plots and 3D plots. You can also customize the processing on waveform using customized MATLAB® scripts on the exported trace data.
PSpice Simulink Co-Simulation Interface allows you to substitute electronic blocks in PSpice, while the rest of the design is simulated using Simulink.
You can access co-simulation option from PSpice output window via Tools -> MATLAB -> Co-Simulation
You can now visualize the required plots in Matlab.
Team DesignTech
Cadence Design Systems
