  2. PSpice
  3. PSpice - Tip of the Week: How to customize information in...
  • Subscribers 31
  • Views 2293
PSpice - Tip of the Week: How to customize information in simulation output file.
DesignTech
DesignTech over 3 years ago
You can select the types of information PSpice saves to the simulation output file.
Go to PSpice -> Edit Simulation Profile -> Options and select General under Output File as shown below:
The following tables defines all the options in the tab for the Output file category:
Flag option
Meaning
ACCT
Summary and accounting information is printed at the end of all the analyses (refer to your PSpice User’s Guide for further information on ACCT).
EXPAND
Lists devices created by subcircuit expansion and lists contents of the bias point file.
LIBRARY
Lists lines used from library files.
LIST
Lists a summary of the circuit elements (devices).
NOBIAS
Suppresses the printing of the bias point node voltages.
NODE
Lists a summary of the connections (node table).
NOECHO
Suppresses a listing of the input file(s).
NOMODE
Suppresses listing of model parameters and temperature updated values.
NOOUTMSG
Suppresses simulation error messages in output file.
NOPAGE
Suppresses paging and the banner for each major section of output.
OPTS
Lists values for all options.
NUMDGT
Number of digits in printed values. This is 4 by default.
WIDTH
same as the .WIDTH OUT= statement
(can be set to either 80 or 132)
Default is 80.
Team DesignTech
Cadence Design Systems
