  2. PSpice
  3. Special symbols available in PSpice
  • Subscribers 30
  • Views 6667
DesignTech
DesignTech over 3 years ago
PSpice Special library provides parts used in simulation flow for special purposes. These are not electrical parts but are used in schematics to perform special functions. For e.g. Watch1
Part Name: Watch1
Use this component to insert .WATCH command in your simulation. This component enables you to observe voltage at node in simulation status windows while simulation is in progress as shown below
Attach this part at node or net which you will like to observe during the simulation. After this, you need to define following three parameters on symbol instance:
 ■ Analysis: Assign the one of the following three values depending upon the type of
analysis being performed:
❑ DC
❑ AC
❑ TRAN
■ HI: Assign a numeric value to define upper limit of voltage
■ LO: Assign a numeric value to define lower limit of voltage
Simulator pauses if voltage at node is outside of range defined by HI and LO
Team DesignTech
Cadence Design Systems
