  2. PSpice
  3. UC1825 Unencrypted TINA-TI Transient Spice Model
  • State Suggested Answer
  • Answers 1
  • Subscribers 31
  • Views 10089
mmartin2
mmartin2 over 3 years ago
I'm using Cadence Allegro Design Entry CIS 17.4-2019 S035.
I downloaded the UC1825 Unencrypted TINA-TI Transient Spice Model library file from Texas Instruments website.
I created a .OLB file from it and imported it into my simulation schematic.
I receive the following errors when I attempt to run pspice simulation.
Reading and checking circuit
ERROR(ORPSIM-16362): Name on .ENDS does not match .SUBCKT
ERROR(ORPSIM-15461): Incorrect number of interface nodes for X_U53.XU8.XU5.
ERROR(ORPSIM-15461): Incorrect number of interface nodes for X_U53.XU1.XU1.
Circuit has errors ... run aborted
See output file for details
INFO(ORPROBE-3188): Simulation aborted
I cannot determine where the syntax error is. Everything appears fine when i look at the .LIB file.
  • TechiEE12
    0 TechiEE12 over 3 years ago
    I found this article on support.cadence.com which might help
    ERROR(ORPSIM-16362): Missing .ENDS in SUBCKT (cadence.com)
  • retiredEE
    0 retiredEE over 3 years ago
    In the UC1825 library there is a subcircuit named COMPARATOR_3 whose name doesn't match the name given in the .ENDS command.  That name is COMP_BASIC_GEN but should be COMPARATOR_3. The other two errors involve the passing of a local subcircuit node into another subcircuit which uses this node only in a VALUE expression.  See DPST_SWITCH_0 called from RC_CLK_0 and SPDT_SWITCH_0 called from ERRAMP_0.  I'm not sure this is valid.  See the section in your PSPice User guide "Net names and device names in ABM expressions".
  • retiredEE
    0 retiredEE over 3 years ago in reply to retiredEE
    I've been obsessed with this problem since the syntax at first glance seems normal.  However, a closer look at subcircuits DPST_SWITCH_0 and SPDT_SWITCH_0 reveals their PARAMS: keyword has a space between M and : which causes PARAM to be interpreted as a node.  This results in the "Incorrect number of interface nodes" errors.
  • mmartin2
    0 mmartin2 over 3 years ago in reply to retiredEE
    Thank you for catching those syntax errors. I removed many other spaces in PARAM. There were also many other spaces removed after .subckt <name>. I also found the D_D10 and D_D11 in .SUBCKT DFFSBRB_SHPBASIC_GEN had incorrect syntax. I'm able to get my simulation running after fixing all of these errors. However, now it appears there is no closed loop regulated control.
