  2. PSpice
  3. EMI Analysis interleaved PFC ucc28070
  • State Suggested Answer
  • Answers 1
  • Subscribers 31
  • Views 6428
Philip123
Philip123 over 3 years ago
Hello, I have simulated a PFC with the ucc28070 in PSPICE. Now I would like to design the input filter. Is there a possibility to analyze the circuit for EMI in PSPICE?
  • AyushD
    0 AyushD over 3 years ago
    Hello
    There is no direct analysis type to simulate EMI but you can use different type of sources like Noise / Impulse etc to check the response of your circuit by configuring these sources as per your need.
    You can place these sources from Modeling Applications. To access Modeling Application go to Place -> PSpice Component -> Modeling Application. You can select Independent Sources under Sources tab to access below window.
    You can use these sources in your design to see your circuit response.
    Hope it helps.
  • TechiEE12
    0 TechiEE12 over 3 years ago
    You can try Cadence Sigrity for EMI analysis with your board file. Reach out to the Sigrity community at https://community.cadence.com/cadence_technology_forums/system-analysis/f/sigrity or check out this tutorial to get started EMI Simulation Tutorial -- Getting Started (cadence.com)
