  2. PSpice
  3. Problem when I run the unencrypted library file
  • Replies 7
  • Subscribers 33
  • Views 8687
Bryce X
Bryce X over 3 years ago
Hi expert,
Nice to meet you here. Recently I used PSpice to generate the lib file and so that I could pass it to the customer. But something went wrong when I run the simulation. Before I do the "create the netlist action", it is ok to run the simulation with the source file. But after I generate the Lib and OLB file, The error message is as below, do you have any idea about this? Thanks.
  • Bryce X
    0 Bryce X over 3 years ago in reply to AyushD
    Hi Ayush,
    Thank you for your suggestions, I have installed the latest hotfix as you advised, but the error still exists, do you have any more ideas?
  • HIMS
    0 HIMS over 2 years ago
    This IC TPS55288 has 2 pins SW2 and SW22. Just before the error statement, you have 2 .IC statements to define the voltage of node/net SW2 - this is being read as error statement - Node's voltage already set.
    Try omitting 1 of the .IC statement and see if it helps.
