  2. PSpice
  3. Problem when I run the unencrypted library file
  • Replies 7
  • Subscribers 33
  • Views 8687
Bryce X
Bryce X over 3 years ago
Hi expert,
Nice to meet you here. Recently I used PSpice to generate the lib file and so that I could pass it to the customer. But something went wrong when I run the simulation. Before I do the "create the netlist action", it is ok to run the simulation with the source file. But after I generate the Lib and OLB file, The error message is as below, do you have any idea about this? Thanks.
  • AyushD
    0 AyushD over 3 years ago
    What is tool version and hotfix you are using ?
  • Bryce X
    0 Bryce X over 3 years ago in reply to AyushD
    Hi Ayush,
    Allergo 2019 - Cadence was used.
  • AyushD
    0 AyushD over 3 years ago in reply to Bryce X
    Hello Bryce,
    I can see that you are using the 1st hotfix "S001" which is very old.
    I would suggest you to install the latest hotfix i.e. S037 which is available on downloads.cadence.com
    With latest hotfix it should be resolved.
  • Bryce X
    Hi Ayush,
    Thanks for reply, could you help me with the download link of the hotfixS037? I didn't find it from the downloads.cadence.com.
  • AyushD
    You can download the latest hotfix from below link
    https://downloads.cadence.com/ESDWeb/ReleaseDetail.eo?methodToCall=viewReleaseDetail&releaseName=SPB174&platform=WINDOWS&displayEngName=OrCAD%2FAllegro%2017.4%20(SPB174)
    Select the OS as Windows and download the media for latest hotfix i.e. 037 and install it. Refer below image for reference.
