  2. PSpice
  3. Buck, Boost, and LDO Generic models. Simulating a signal...
  • State Verified Answer
  • Subscribers 31
  • Views 6480
Buck, Boost, and LDO Generic models. Simulating a signal through a VCVS
ceadebi
ceadebi over 3 years ago
Are there any generic models for a buck boost and LDO. Also is there a way for it to show up on a graph of combining the output of a switch with a VCVS.. When using a DC sourse or a pulse voltage source, there is no update on the output of the circuit in the graph, so is there a way for there to be continuous update from the switches as well as the VCVS.
  • TechiEE12
    TechiEE12 over 3 years ago +2 verified
    To get continuous update while running the simulation make sure your Probe Window settings are like this With Cadence installation there are few buck boost converter models provided. You can search…
  • TechiEE12
    +1 TechiEE12 over 3 years ago
    With Cadence installation there are few buck boost converter models provided. You can search in PSpice part search window.
    If you have any specific manufacturer in mind then you may check the vendor's website for PSpice models of the same.
    • Vote Up +2 Vote Down
