  2. PSpice
  3. Simulation cannot run
  • Subscribers 31
  • Views 5956
Hannah12
Hannah12 over 3 years ago
Hello everyone! I need a little help here. I'm trying to simulate this cct using PSpice from LM338 datasheet of Texas Instrument and I'm not sure if this is the right value and graph that I should be getting? Thank you in advance for your help! cct2_run.pdf
  • oldmouldy
    0 oldmouldy over 3 years ago
    If you are implementing Figure 35 from the datasheet, you are missing a negative supply for the LM317 to connect to and no load to sink the current from the LM338.
  • Hannah12
    0 Hannah12 over 3 years ago in reply to oldmouldy
    hello, yes im implementing the circuit from figure 35 of the datasheet. may i ask what do you mean by no load to sink current from the lm338?
