  2. PSpice
  3. ERROR(ORPSIM-16578): PSpice A/D Basics does not support...
  • State Verified Answer
  • Subscribers 32
  • Views 3335
ERROR(ORPSIM-16578): PSpice A/D Basics does not support TLine device. To simulate this device model, upgrade to a higher license.
SergeyM
SergeyM over 3 years ago
I'm trying to run a simulation with a part from the TI site. It fails with the message "ERROR(ORPSIM-16578): PSpice A/D Basics does not support TLine device. To simulate this device model, upgrade to a higher license."
Could you please explain if this is indeed a license problem or if it fails because the file is from TI?
  • oldmouldy
    oldmouldy over 3 years ago +2 verified
    Yes, it's a licensing issue. The combination of PSpice version and license that you have doesn't support simulation of the TLine, transmission line, model used by the device you are using. You would need…
  • oldmouldy
    +1 oldmouldy over 3 years ago
    Yes, it's a licensing issue. The combination of PSpice version and license that you have doesn't support simulation of the TLine, transmission line, model used by the device you are using. You would need a different version / license combination to be able to run a simulation of a circuit using the device.
    • Vote Up +2 Vote Down
