  2. PSpice
  3. How could I control the output waveform interpolation in...
  • State Suggested Answer
  • Answers 1
  • Subscribers 30
  • Views 1833
How could I control the output waveform interpolation in Pspice project or Netlist while using V/I pwl file?
Havior
Havior over 3 years ago
I want to realize the function like the '.option interp' in Synopsys Hspice, it can make the output sample at equal intervals. I have tried it in Cadence Pspice and found the Output File Options in Simulation Settings can do it. Howerer, it only works using like Pulse Source. When using the PWL source, it can't properly work. It really puzzled me and I want to know how to solve it.
  • AyushD
    AyushD over 3 years ago +1 suggested
    I believe you are talking about controlling the step size of the output waveform. In PSpice you have the option to define the Max Step Size and tool will not use the step size more than the value defined…
  • AyushD
    0 AyushD over 3 years ago
    I believe you are talking about controlling the step size of the output waveform. In PSpice you have the option to define the Max Step Size and tool will not use the step size more than the value defined.
    You can not define the exact step size that tool will use while simulating any design.
